Re: Which gearbox do I have?
1 Attachment(s)
Yes that’s where got the above codes from. But when search on any of them to try and find which atf I need I get very vague results. 😔
A 7 speed CVT - not a good one ?
Quote:
Originally Posted by
Gazwould
hi. Sorry, So are you saying one of those codes say I defo have the cvt or is it just that it might be the cvt and is rubbish?
cheers.
Fleagleuk
Any reason to think it's not up to 7.5l (4.5l-5l for change, but no idea if you've drained it completly) of G052180A2 ATF for a 0AN300041R LDU 'box?
There is a warning "The Continuously Variable Automatic Transmission Multitronic 01J requires a different ATF than shift automatics." Maybe outlets aren't taking heed of that and are listing "regular" ATF wrongly?
VAG-Abound
I know it’s dumped a fair bit over my drive way so I have no idea what’s left in side. Luckily it happened just a few hundred meters from the house. But of course there was little traction as the torque converter wasn’t pressured. 😔
Is it not best to drain it now? At least then you’ve done an oil change and get the correct amount in.
Well a litre of fluid would cover a square metre or so. Fix up the leak, drain box as if doing a change to clean container, see how short you are of 5l, put it back in and order enough to top up would be my approach.
Sounds like my plan! Thanks. :beerchug:
