Re: Bora Driver Seat Change
Disconnect the battery, then wait 30 minutes before disconnecting the seat loom.
Thanks for the help much appreciated:beerchug:
Whats the reason for waiting 30 minutes?
Thanks. I've heard that should be done when powering down a PC and similar electronic equipment. Just read a little bit about it after a google search. Its 30 mins to allow the airbag capacitor to discharge so the bags dont deploy. Some modern bags may need less time but from what I've read 30 mins is a good safe time.
The airbag warning light will be on when you re-connect the battery. You'll need VCDS or bring it to someone with VCDS to extinguish the light
