Suspension Level Control Calibration in the uk but not at dealer.
ok after replacing my front air shocker that had a leak..on fixing it all back up together i now have adifferent error .. solid yellow light still dropped at the front.. the mmi display shows all greyed out on all levels even jacking mode is not a option.. i will recheck all connections..oddly i dont have the strong hissing noise which im normally hearing .. the pump is newish last year replaced.. it might need re leveling i guess... apart from dealer would anyone know of uk garages maybe even mobile...
Re: Suspension Level Control Calibration in the uk but not at dealer.
Ok all fixed .. after re checking the next day .. without the rain and also not at 1.am .. I noticed the leveling control arm had become loose..all level know . all I have to do now is to replace the abs sensor that I broke . then back to the mot center...oh and replece the center seat belt clamp... kids had pushed somthing inside it..
The center seat clamps only fit one round if you are having trouble switch the buckle into the opposite clamp.
