would like to retrofit cruise conrol and bluetooth to my 2010 eos
as per title am looking at fitting cruise control and bluetooth to my eos its a 03/2010 model with no steering wheel controls
have just perchased a rcd 510 dab to replace the 310 dab
am going to invest in the vcds so i can do my own coding
what parts do i need part no would be helpfull
cheers
Re: would like to retrofit cruise conrol and bluetooth to my 2010 eos
Welcome to VWAF
Bluetooth kit you'll need - VW Bluetooth KIT 7P6035730N - Retrofit - Newest Version
For cruise you will need to check the revsion of your steering control module is compatible with cruise.
Suggest you post on the Golf part of the forum - electrics are essentially the same and the Eos forum usually has tumbleweed blowing through it.
Dealers used to fit cruise for £150, which is good value considering parts are about £75. I had it done on my wife's Eos. Same time, they had massive problems getting cruise to work on my GTI and ended up swapping all manner of stuff so I was glad I'd not gone DIY.
having don a vag scan
it has a h/w 5k0 953 569 s/w 1k5 953 521 A so if i understant it right this is copatable to add cruise control???
have now fitted the rcd 510
have posed my scan for input as its shown up son faults and would like to get these rectified befor my warrenty runs out so if any one could give me some insite on what they meen would be verry helpful wile im learning
cheers
satman789456
01-Engine -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
26-Auto Roof -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 PM HW: 03L 906 022 G
Component: R4 2,0L EDC 0000SG 5680
Revision: 13H03--- Serial number:
Coding: 0001072
Shop #: WSC 00020 790 00000
VCID: 7F0D1ABD2EFB33E6E2D-802A
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 563B6008092300016A0D06E490210082340000
VCID: 78FFF1A1CBD504DEA37-802D
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AC HW: 3C8 907 336 AC
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000000002
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_Climatic A01005
ROD: EV_ClimaBasis_SE36.rod
VCID: 6ED3D7F9B1914A6E79B-803B
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 C HW: 5K0 937 086 C
Component: BCM PQ35 M 011 0028
Revision: BC011001
Coding: 48000A3B9A25F060400000801400012443515488712085605C 8000000000
VCID: 34670591973D20BE4FF-8061
Subsystem 1 - Part No: 1Q2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 10021 22 0512
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 170210 05 54 0403
Coding: 0330CD
Subsystem 3 - Part No: 1Q0 951 177 C
Component: Innenraumuebe 200 0203
Coding: 000000
Subsystem 4 - Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
Coding: 000000
Subsystem 5 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
Coding: 000000
2 Faults Found:
01135 - Interior Monitoring Sensors
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 4
Fault Frequency: 1
Reset counter: 203
Mileage: 88162 km
Time Indication: 0
Date: 2049.14.04
Time: 11:20:44
Freeze Frame:
Term 15 Off
Voltage: 12.15 V
OFF
OFF
OFF
OFF
OFF
01838 - Transceiver Module 2 for Interior Monitoring (G305)
Fre
As you say tumbleweed on the EOS forum, but some useful specific info here.
Up to week 44 of 2009 production, the 'cheap' retro fit option will work. I've found this out having just bough a 2009 59 plate. Turns out it was built in week 48 of 2009 (nice chassis number ending 012345 though!!) so more expensive cruise option is required at around £370. Apparently there's another break in the production spec in around May 2010 when a full update was released and cruise on that is around £315 to retrofit....
