2.0 tdi BRE engine injector removal.
Hi. I looking around the internet and nothing. I have 2.0 tdi BRE 140bhp audi a6 c6. I want to replace injectors seals and tandem pump gasket. BUT i cant find any info about how easy is to remove these injectors. Only i find are other audi injectors..Nothing about Bre angine..different injectors. What i found has 4 seals but Bre engine 2 seals.
Is any of you here with same engine done it and how tight they sit in the hole.
Thank you in advance
Re: 2.0 tdi BRE engine injector removal.
I found now video about injectors i need but it has missing bit at point how they got it loose .You can see clip is jumping. and looks like it is in Polish language. Still dont know how much hassle was it actually to get it out :D
Wymiana pompo wtryskiwacza /Audi/ VW / - YouTube
Quote:
Originally Posted by
dan2485
These not same. These has 4 seals and come out easy. BRE injectors has only 2 seals and thats why im worried. That maybe injector housing it self is used to seal it. Same as older cr diesel injectors. The ones sit in the hole so tight that even by beating **** out of them they not moving.
You have to carry out a measurement from side of cylinder head to a point on each Injector to accurately align the injector inside the cylinder head. Did you tube show that??
3 Attachment(s)
will do some research but these injectors have 2 bolt holes on injector it self. That holds them down. Looks like you cant put it wrong. I Think just line up holes on injector and head and should be ok. Other audi injectors dont have them.Attachment 35788 Part marked with red circle is that i think may be stuck in head. as it has only 2 seals but something must hold that pressure. i whish that i had the ones with 4 seals.Attachment 35789
imtattoo80
Attachment 35789
Okay, just make sure you`ve a calibrated eye when you nip the clamp.https://workshop-manuals.com/volkswa...-mk5-12445.png
Alan02
But thats not a 16v BRE engine in your pic
