Re: Import Speed camera locations new Q7
Hi Gyro, I always go the SD route as changing the zoomlevel so you can actually see the icons is important for me.
Have you tried reformatting the SD card from a windows computer. I think it needs to be fat32 from a distant memory.
I use a Mac to upload new data but I think I may have originally formatted on windows.
Quote:
Originally Posted by
srbsq7
Yeah tried reformatting and neither of the two SD cards are recognised in either of the car's SD slots. Download from my Audi still not working either. Giving up now.
If you PM your email address I can send you the recent upload I did. You should be able to just copy to SD and import.
Cheers mate. The engineer in me kept me going and I actually went all the way back to the start - deleted the files in My Audi and downloaded the most recent ones, sent them back to the car, but before I tried to download them I updated the maps in the satnav. Followed Andy's superb multi-post tutorial thereafter and everything worked a treat after that.
Still got an issue with the SD cards not being read by the car but I'm glued to the PC as on duty this weekend, so in between trying to solve offshore drilling problems I'll be trying to sort out me SD cards!
Scott
Make sure when you're formatting the cards you use FAT32, not exFAT or NTFS. Larger cards need one of these to work but the Audi MMI only supports FAT32. Windows moved away from FAT32 a long time ago so will try to use NTFS by default which won't be supported in the car but will look fine on your computer.
I have the same SD card issue Gyro....
I don’t recall it being this hard but what about this link:
https://digiex.net/threads/format-sd...c-cards.14179/
I managed to successfully download to car. But when I try utilising the SD card version (after amended zoom), I just cant get it to work. Keep getting issue update interrupted. I have tried diff SD cards, formatted in Mac/ windows, ex-fat, FAT 32 but still issues. Does anyone else have any suggestions I can try please?
I just did mine today. I'm using a 32gb SD formatted as ExFAT. PM your email address and I can send you the files I uploaded if you want to rule it out.
srbsq7
Thanks mate I have PM address.
