Is it possible to auto close the avant boot from the keyfob or from the drivers seat ?
Currently I can only close the boot if I press the button on the bottom of the boot lit.
Printable View
Easily done with vcds.
I can hold in the boot opening button from the drivers seat to close the boot on my avant. You just have to keep the button pressed while it's closing.
Mine closes on the key. You have to be relatively close to the car for some reason, press and hold the boot button and it closes and beeps as it closes
Yes it can be done, needs activating with Vcds
Sent from my iPhone using Tapatalk Pro
beep can be removed, and changed to tap instead of "hold" so it closes with just one momentarily press. Also there is setting to operate in longer distances, mine does ~ 20-30 metes away. Look at the vcds tricks stickie on top of threads. It won't work from inside the car as the car detects that the key is inside.
Yeah but we could not get it to work on my MY14 allroad....
Tried mine today. Standing behind the car, pressing and holding the remote button (open boot) and the boot starts beeping and closing :D had no idea it worked!
Tried mine as well, but doesn't work! :-( I wonder why some work and others do not?
