My golf has recently started going into limp mode. I can cruise along at 65/70mph for a while and when i need to overtake by planting the throttle the limp mode kicks in. If i restart the car it goes away. It can be on a flat road surface or an incline (like a slip road)
Ive done a vcds scan and here are the results:
Address 01: Engine (J623-CFGB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 BC HW: 03L 907 309 R
Component: R4 2,0L EDC H23 7819
Revision: 42H23--- Serial number: 00000000000000
Coding: 001D0012040500080000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ECM20TDI01103L906018BC 003005
ROD: EV_ECM20TDI01103L906018BB_003_VW36.rod
VCID: 6CD772B2878BF124D4-8038
1 Fault Found:
5211 - Fuel Rail/System Pressure
P0087 00 [101] - Too Low
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 146606 km
Date: 2018.07.02
Time: 14:31:25
Engine speed: 2578.00 /min
Normed load value: 99.6 %
Vehicle speed: 108 km/h
Coolant temperature: 89 °C
Intake air temperature: 40 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 13.880 V
Unlearning counter according OBD: 80
Fuel temperature: 57.3 °C
Mean injection quantity: 65.51 mg/stroke
Rail pressure regulation: status-Bits 0-7: 5
Fuel high pressure: actual value: 1.133e+006 hPa
High fuel pressure: specified value: 1.3832e+006 hPa
Pressure control valve adaptation factor: 0.9655
Fuel level: 28.00 l
Readiness: 0 0 0 0 0
Could the pressure sensor be faulty as another time i scanned it said short to ground G247, or is it more like the lift pump is clogged and or fuel filter?
Anyone had this issue before and if so what was the solution?
Steve
