Do You have VCDS
I have noticed that a lot of the VCDS data available on the web is out of date and so incorrect for B6 Passat engines. E.g. most information on the web will tell you that a 1.9 pd engine idle speed should about 850 – 970 /min. This is not correct for the BKC 1.9 pd in a passat.
To try to improve information I want to collect VCDS engine data block info for Passat B6 diesels, 1.9 pd and 2.0 pd. Once I have enough info I will put the basic info on the web for us all to refer to. Eventually I will need logs for idle and 3000/min but at present I am only looking for idle logs.
To go with the log I must have year and engine code. Without that info the log is no good.
So, if you have VCDS, please do an idle log for your car and send me the data via the forum.
My intention is to end up with reference logs for different engine codes that we can refer to when looking for a fault. These logs must therefore come from cars with no known faults.
My first example:
This is a VCDS log of engine data blocks for a B6 1.9 tdi BKC at idle. No faults.
(I have removed empty groups to shorten it)
Thursday,29,July,2010,11:34
VCDS Version: Release 10.6.0
Data version: 20100630
Address 01: Engine (03G 906 021 DP)
Group 001: Injection Quantity
819 /min Engine Speed (G28)
5.8 mg/str Injection Quantity
7.1°KW Injection Duration (specified)
75.6°C Coolant Temperature (G62)
Group 002: Idle Speed
0.0 % Accel. Pedal Pos. Sensor 1 (G79)
0 01 0 Operation Status
Group 003: Exhaust Gas Recirculation (EGR)
240.0 mg/str Exhaust Gas Recirculat. (spec.)
430.0 mg/str Exhaust Gas Recirculat. (actual)
95.5 % Exhaust Gas Recirc. Duty Cycle
Group 004: Pump-Jet Valves
0.0 °BTDC Injection Start (specified)
-0.5°KW Torsion Value
Group 005: Start Conditions (last Engine Start)
13.5 mg/str Start Injection Quantity
48.0 Start Synchronisation
Group 006: Cruise Control System (CCS)
0.0 km/h Vehicle Speed (actual)
11000000 Pedal Monitoring
00000000 Switch Monitoring
Group 007: Temperatures
59.4°C Fuel Temperature (G81)
39.6°C Intake Air Temperature (G72)
Group 008: Injection Quantity Limitation I (Torque Limitation)
0.0 Nm Torque Request (Driver)
168.4 Nm Torque Limitation
153.7 Nm Smoke Limitation
Group 009: Injection Quantity Limitation II (Torque Limitation)
-1280.0 Nm Torque Request (Cruise Control)
500.2 Nm Transmission Limitiation
153.7 Nm Torque Restriction
Group 010: Charge Pressure Control
430.0 mg/str Mass Air Flow (actual)
999.6 mbar Atmospheric Pressure
1030.2 mbar Boost Pressure (actual)
Group 011: Charge Pressure Control
1091.4 mbar Boost Pressure (specified)
80.1 % Charge Pressure Control Duty Cycle
Group 012: Glow Plugs
11111111 Glow Status
0.00 s Pre-Glow Period
14.44 V Supply Voltage (Terminal 30)
76.5°C Coolant Temperature (G62)
Group 013: Idle Stabilization (Injection Quantity Deviation)
-0.42 mg/str Injection Quantity Deviation Cyl. 1
-0.52 mg/str Injection Quantity Deviation Cyl. 2
0.71 mg/str Injection Quantity Deviation Cyl. 3
0.21 mg/str Injection Quantity Deviation Cyl. 4
Group 015: Fuel Consumption
39.0 Nm Engine Torque
0.60 l/h Fuel Consumption
Group 016: Auxiliary Heating
31.4 % Generator Load
14.36 V Supply Voltage (Terminal 30)
Group 017: Readiness Code (EOBD)
00000000 CARB Mode 01 DATA A
00000110 CARB Mode 01 DATA B
10000000 CARB Mode 01 DATA C
00000000 CARB Mode 01 DATA D
Group 018: Injector Status
0.0 Injector Status Cylinder 1
0.0 Injector Status Cylinder 2
0.0 Injector Status Cylinder 3
0.0 Injector Status Cylinder 4
Group 020: Injection Quantity Limitation (from ABS)
1270.0 Nm ASR Limitation
-1280.0 Nm MSR Limitation
Group 021: CAN-Databus Status (Powertrain)
00000000 Engine Electronics
Transmission Electronics
00000000 Brake Electronics
00000100 Brake Electronics (ESP)
Group 022: Shut-Off Status
0.0 Shut-Off Status Cruise Control
0.0 Switch Monitoring Cruise Control
0.0 Shut-Off Status Charge Pressure
0.0 Shut-Off Status Climate Control
Group 023: Injector Switch Time Deviation
-19.0 Switch Time Deviat. Cylinder 1
-24.0 Switch Time Deviat. Cylinder 2
-11.0 Switch Time Deviat. Cylinder 3
-11.0 Switch Time Deviat. Cylinder 4
Group 025
840 /min Engine Speed (G28)
4.0 (no units)
1.0 (no units)
Group 028: Accelerator Pedal Position Sensor
0.760 V Accel. Pedal Pos. Sensor 1 (G79)
0.380 V Accel. Pedal Pos. Sensor 2 (G185)
Group 029: Temperature and Oil Level Sensor (TOG)
72.0°C Oil Temperature
30.0 mm Oil Level
9.0 Wear Index
21.0 Soot Index
Group 039
819 /min RPM
5.8 mg/str Inj. Quantity
0.00 mg/str Inj. Quantity
00000010 Bin. Bits
Group 040
819 /min RPM
Group 041
100.6 % Duty Cycle
4.8 % Duty Cycle
101.6 % Duty Cycle
94.8 % Duty Cycle
Group 042
0.0 % Lambda
00000000 Bin. Bits
100.6 % Duty Cycle
101.6 % Duty Cycle
Group 044
819 /min RPM
440.0 mg/str Mass Air / Rev.
1 Bin. Bits
Group 045
969.0 mbar Absolute Pres.
11.38 g/s Mass Flow
1030.2 mbar Absolute Pres.
Group 046
100.6 % Duty Cycle
0.0 % Duty Cycle
99.8 % Duty Cycle
95.9 % Duty Cycle
Group 047
0.0 % Lambda
0.0 % Lambda
95.9 % Duty Cycle
99.8 % Duty Cycle
Group 050
819 /min RPM
00000010 Bin. Bits
Group 051: Engine Speed Recognition
399 /min Camshaft Speed
01010000 Shut-Off Status Injection Sequence
Group 055
0.0 (no units)
0.0 (no units)
00100000 Bin. Bits
00100000 Bin. Bits
Group 056
00100000 Bin. Bits
00100000 Bin. Bits
00100000 Bin. Bits
0xFF00 Hex Value
Group 062: Engine Cooling (Temperatures)
80.1°C Coolant Temperat. Engine Output
34.2°C Coolant Temperat. Cooler Output
18.0°C Ambient Temperature
40.5°C Intake Air Temperature
Group 063: Engine Cooling (Climate Control)
7.16 bar Refrigerant Pressure
0.0 Nm Load Torque
Cooling Request
Group 064: Engine Cooling
80.1°C Coolant Temperature (G62)
10.1 % Coolant Fan 1 Duty Cycle
Group 082: Advanced Control Module Identification III
0000000000000 <> 78 01JJ 79 <>
Group 086: EOBD
11010000 Bin. Bits
11111110 Bin. Bits
10011111 Bin. Bits
11111111 Bin. Bits
Group 087: EOBD
11111111 Bin. Bits
11111111 Bin. Bits
11001111 Bin. Bits
Group 089
00000000 Bin. Bits
00000110 Bin. Bits
10000000 Bin. Bits
00000000 Bin. Bits
Group 090: EOBD/OBD-2 Exhaust Gas Recirculation (EGR) I
00000000 Status Control Deviation
Group 091
323.85 (no units)
-326.40 (no units)
240.0 mg/str Mass Air / Rev.
-201.45 (no units)
Group 093
00000000 Bin. Bits
0.93 (no units)
11.38 g/s Mass Flow
11.38 g/s Mass Flow
Re: Do You have VCDS
When I get mine read on Sat i will ask for a printout after all faults have been cleared.
I wish I knew what all that meant..I have no clue but when I get my car VCDS soon ill copy it here..hopefully someone can explain in time what it all means.
Thanks once again Martin :D
If you can tell me how to do it I'll do it. :D
I have put "how to log" here. https://sites.google.com/site/1810martin/vcds-data-log
and a speed log method here. https://sites.google.com/site/1810ma...data-in-one-go
Hope this helps. All info is from ross-tech site.
Address 01: Engine (03G 906 018 CE)
'56 Passat 2.0 TDi BKP 140 SE Estate
Group 001:
Injection Quantity
1 Engine Speed (G28) 799 /min RPM,
2 Injection Quantity 3.5 mg/str Inj. Quantity,
3 Injection Duration (specified) 2.6°KW Idle Stabilization,
4 Coolant Temperature (G62) 70.0°C Temperature,
Group 002:
Idle Speed
2 Accel. Pedal Pos. Sensor 1 (G79) 0.0 % Duty Cycle
3 Operation Status 00001000 Bin. Bits
Group 003:
2 Exhaust Gas Recirculat. (spec.) 1388.8 mg/str Mass Air / Rev.
3 Exhaust Gas Recirculat. (actual) 418.1 mg/str Mass Air / Rev.
4 Exhaust Gas Recirc. Duty Cycle 0.0 % Duty Cycle
Group 004:
Pump-Jet Valves
1 Engine Speed (G28) 803 /min RPM
2 BTDC Injection Start (specified) 4.0 °ATDC Ign. Timing
3 Injection Duration (specified) 2.5°KW Idle Stabilization
4 Torsion Value 0.00° Steering Angle
Group 005:
2 Start Injection Quantity 0.0 Nm Torque
3 Start Synchronisation 255.0 (no units)
Group 006:
1 Vehicle Speed (actual) 0.0 km/h Speed
2 Pedal Monitoring 00001000 Bin. Bits
3 Accel. Pedal Pos. Sensor 1 (G79) 0.0 % Duty Cycle
4 Switch Monitoring 00000000 Bin. Bits
1 Fuel Temperature (G81) 59.0°C Temperature
2 Fuel Cooling status
3 Intake Air Temperature (G72) 33.0°C Temperature
1 Engine Speed (G28) 796 /min RPM
2 Torque Request (Driver) 0.0 Nm Torque
3 Torque Limitation 190.0 Nm Torque
4 Smoke Limitation 132.0 Nm Torque
2 Torque Request (Cruise Control) -988.8 Nm Torque
3 Transmission Limitation 1024.0 Nm Torque
4 Torque Restriction 132.0 Nm Torque
1 Mass Air Flow (actual) 417.2 mg/str Mass Air / Rev.
2 Atmospheric Pressure 1018.9 mbar Absolute Pres.
3 Boost Pressure (actual) 1002.2 mbar Absolute Pres.
4 Accel. Pedal Pos. Sensor 1 (G79) 0.0 % Duty Cycle
1 Engine Speed (G28) 807 /min RPM
2 Boost Pressure (specified) 1002.2 mbar Absolute Pres.
3 Boost Pressure (actual) 1001.9 mbar Absolute Pres.
4 Charge Pressure Control Duty Cycle 80.0 % Lambda
1 Glow Status 11111111 Bin. Bits
2 Pre-Glow Period 0.00 s Time
3 Supply Voltage (Terminal 30) 14.003 V Voltage
1 Injection Quantity Deviation Cyl. 1 -0.11 mg/str Inj. Quantity
2 Injection Quantity Deviation Cyl. 2 0.13 mg/str Inj. Quantity
3 Injection Quantity Deviation Cyl. 3 0.01 mg/str Inj. Quantity
4 Injection Quantity Deviation Cyl. 4 -0.02 mg/str Inj. Quantity
Group 015:
Fuel Consumption
1 Engine Speed (G28) 794 /min RPM
2 Engine Torque 23.5 Nm Torque
3 Fuel Consumption 0.24 l/h Fuel Consump.
4 Torque Request (Driver) 0.0 Nm Torque
Group 016:
Auxiliary Heating
1 Generator Load 32.5 % Load
2 Auxiliary Heating,Shut-Off Conditions 11000000 Bin. Bits
3 Heating Element Activation 252 Count
4 Supply Voltage (Terminal 30) 13.892 V Voltage
1 CARB Mode 01 DATA A 00000000 Bin. Bits
2 CARB Mode 01 DATA B 00000110 Bin. Bits
3 CARB Mode 01 DATA C 10000000 Bin. Bits
4 CARB Mode 01 DATA D 00000000 Bin. Bits
Group 018:
Injector Status
1 Injector Status Cylinder 1 0.0 (no units)
2 Injector Status Cylinder 2 0.0 (no units)
3 Injector Status Cylinder 3 0.0 (no units)
4 Injector Status Cylinder 4 0.0 (no units)
Group 019
1 137.00 V Voltage
2 135.25 V Voltage
3 142.00 V Voltage
4 135.75 V Voltage
1 Engine Speed (G28) 805 /min RPM
2 Engine Torque 21.4 Nm Torque
3 ASR Limitation 1024.0 Nm Torque
4 MSR Limitation 0.0 Nm Torque
1 Engine Electronics 00000000 Bin. Bits
2 Transmission Electronics 01000000 Bin. Bits
3 Brake Electronics 00000000 Bin. Bits
4 Brake Electronics (ESP) 00000100 Bin. Bits
1 Shut-Off Status Cruise Control 1 Count
2 Switch Monitoring Cruise Control 0.0 (no units)
3 Shut-Off Status Charge Pressure 0.0 (no units)
4 Shut-Off Status Climate Control 0.0 (no units)
Group 023:
1 Switch Time Deviat. Cylinder 1 0.21 ms Time
2 Switch Time Deviat. Cylinder 2 0.22 ms Time
3 Switch Time Deviat. Cylinder 3 0.22 ms Time
4 Switch Time Deviat. Cylinder 4 0.21 ms Time
Group 024
1 765 Count
2 763 Count
3 797 Count
4 741 Count
Group 025
1 Engine Speed (G28) 801 /min RPM
2 Status Terminal 50
3 Engine Condition Idle
4 Start Cancel Conditions 237.0 (no units)
Group 027
1
2
3 0.0 km/h Speed
4 300.0 km/h Speed
1 Accel. Pedal Pos. Sensor 1 (G79) 0.750 V Voltage
2 Accel. Pedal Pos. Sensor 2 (G185) 0.380 V Voltage
1 Oil Temperature 64.0°C Temperature
2 Oil Level 29.0 mm Content
3 Wear Index 0 km Mileage
4 Soot Index 0 km Mileage
Group 041
1 96.0 % Duty Cycle
2 0.0 % Duty Cycle
3 -0.1 % Lambda
4 -10.0 % Lambda
Group 042
1 0.688 V Voltage
2 00000000 Bin. Bits
3 95.8 % Lambda
4 -0.1 % Lambda
Group 044
1 799 /min RPM
2 421.2 mg/str Mass Air / Rev.
3 0.0 (no units)
Group 045
1
2 0.0 mbar Pressure
3 11.27 g/s Mass Flow
4 1002.8 mbar Absolute Pres.
Group 046
1 96.0 % Duty Cycle
2 96.0 % Duty Cycle
3 96.0 % Lambda
4 -11.1 % Lambda
Group 047
1 0.507 V Voltage
2 4.628 V Voltage
3 -10.3 % Lambda
4 95.8 % Lambda
1 Engine Speed 795 /min RPM
2 Camshaft Speed 397 /min RPM
4 Shut-Off Status Injection Sequence 00000000 Bin. Bits
Group 053
1 0.051 Nm Torque
2 0.051 Nm Torque
3 0.056 Nm Torque
4 0.050 Nm Torque
Group 054
1 5.51 (no units)
2 5.64 (no units)
3 5.51 (no units)
4 5.39 (no units)
Group 062:
1 Coolant Temperat. Engine Output 74.0°C Temperature
2 Coolant Temperat. Cooler Output 58.0°C Temperature
3 Ambient Temperature 24.7°C Temperature
4 Intake Air Temperature 36.0°C Temperature
Group 063:
1 Refrigerant Pressure 6.60 bar Pressure
2 Load Torque 0.0 Nm Torque
3 Cooling Request 0.0 % Duty Cycle
Group 064:
Engine Cooling
1 Coolant Temperature (G62) 74.0°C Temperature
3 Coolant Fan 1 Duty Cycle 9.8 % Duty Cycle
1 Engine Speed (G28) 797 /min RPM
3 Exhaust Gas Recirculat. (spec.) 1388.8 mg/str Mass Air / Rev.
4 Status Control Deviation 00000000 Bin. Bits
Group 091
1 100.0 % Lambda
2 -100.0 % Lambda
3 1388.8 mg/str Mass Air / Rev.
4 -58.4 % Lambda
Group 093
1 00000000 Bin. Bits
2 0.95 (no units)
3 11.47 g/s Mass Flow
4 10.65 g/s Mass Flow
Group 115
1 3.00 m/s^2 Lateral Accel.
2 -32.0 Nm Torque
3 0.0 Nm Torque
4 0.0 Nm Torque
Group 117
1 0.0 (no units)
2 99.0 (no units)
3 3.00 m/s^2 Lateral Accel.
4 0.00 m/s^2 Lateral Accel.
Group 131
1 0.0 (no units)
2 3.4 mg/str Inj. Quantity
3
4 77.0°C Temperature
Group 133
1 801 /min RPM
2 409.4 mg/str Mass Air / Rev.
3 1004.1 mbar Absolute Pres.
4 0.0 (no units)
Group 150
1 800 /min RPM
2 0.0 Nm Torque
3 255.0 (no units)
4 78.0°C Temperature
Group 151
1 804 /min RPM
2 21.4 Nm Torque
3 190.0 Nm Torque
4 129.8 Nm Torque
Group 152
1 798 /min RPM
2 -2.5 Nm Torque
3 22.7 Nm Torque
4 33.7 % Load
Group 154
1 800 /min RPM
2 1388.8 mg/str Mass Air / Rev.
3 418.3 mg/str Mass Air / Rev.
4 0.0 % Duty Cycle
Group 155
1 801 /min RPM
2 800 /min RPM
3 00001000 Bin. Bits
4 0.0 % Duty Cycle
Group 156
1 801 /min RPM
2 300.0 km/h Speed
3 0.0 km/h Speed
4 22.1 Nm Torque
Group 157
1 795 /min RPM
2 0.00 s Time
3 78.0°C Temperature
4 11111111 Bin. Bits
Group 158
1 798 /min RPM
2 0.0 Nm Torque
3 22.6 Nm Torque
4 0.0 (no units)
Group 161
1 795 /min RPM
2 0 (no units)
3 0.1 l Tank Cont.
4 0 km Mileage
Group 165
1 800 /min RPM
2 -0.3 % Lambda
3 414.8 mg/str Mass Air / Rev.
4 0.0 % Duty Cycle
Group 166
1 801 /min RPM
2
4 80.0 % Lambda
Group 167
1 798 /min RPM
2
3 64.0°C Temperature
4 79.0°C Temperature
Group 168
1
2 0.750 V Voltage
3 0.380 V Voltage
4 0.0 % Duty Cycle
Data courtesy of Bundao
VCDS ENGINE MEASURING BLOCKS 2007 SEL ESTATE 2.0 PD 170 BMR
Group 001:
Injection Quantity, ,
1, Engine Speed (G28), 796 /min
2, Injection Quantity , 5.5 mg/str
3, Injection Duration (specified), 3.9°KW
4, Coolant Temperature (G62), 88.0°C
Group 002:
Idle Speed, ,
1, Engine Speed (G28), 799 /min
2, Accel. Pedal Pos. Sensor 1 (G79), 0.0
3, Operation Status, 00001001
Group 003:
Exhaust Gas Recirculation (EGR), ,
1, Engine Speed (G28), 802 /min
2, Exhaust Gas Recirculat. (spec.), 280.0 mg/str
3, Exhaust Gas Recirculat. (actual), 272.3 mg/str
4, Exhaust Gas Recirc. Duty Cycle, 50.9
Group 004:
Pump-Jet Valves, ,
1, Engine Speed (G28), 804 /min
2, BTDC Injection Start (specified), 5.0 °ATDC
4, Torsion Value, -0.35
Group 005:
Start Conditions (last Engine Start), ,
1, Engine Speed (G28), 800 /min
2, Start Injection Quantity, 0.0 Nm
3, Start Synchronisation, 255.0
Group 006:
Cruise Control System (CCS), ,
1, Vehicle Speed (actual), 0.0 km/h
2, Pedal Monitoring, 00001000
3, Accel. Pedal Pos. Sensor 1 (G79), 0.0 %
4, Switch Monitoring, 00000000
Group 007: Temperatures, ,
1, Fuel Temperature (G81), 71.0°C
2, Fuel Cooling status,
3, Intake Air Temperature (G72), 34.0°C
Group 008: Injection Quantity Limitation I (Torque Limitation), ,
2, Torque Request (Driver), 0.0 Nm
3, Torque Limitation, 170.0 Nm
4, Smoke Limitation, 141.3 Nm
Group 009: Injection Quantity Limitation II (Torque Limitation), ,
2, Torque Request (Cruise Control), -987.5 Nm
3, Transmission Limitation, 1024.0 Nm
4, Torque Restriction, 141.3 Nm
Group 010: Charge Pressure Control, ,
1, Mass Air Flow (actual), 278.0 mg/str
2, Atmospheric Pressure, 1012.4 mbar
3, Boost Pressure (actual), 1011.0 mbar
4, Accel. Pedal Pos. Sensor 1 (G79), 0.0 %
Group 011: Charge Pressure Control, ,
1, Engine Speed (G28), 801 /min
2, Boost Pressure (specified), 1011.0 mbar
3, Boost Pressure (actual), 1011.2 mbar
4, Charge Pressure Control Duty Cycle, 85.1 %
Group 012: Glow Plugs, ,
1, Glow Status, 11111111
2, Pre-Glow Period, 0.00 s
3, Supply Voltage (Terminal 30), 14.118 V
1, Injection Quantity Deviation Cyl. 1, 0.06 mg/str
2, Injection Quantity Deviation Cyl. 2, -0.14 mg/str
3, Injection Quantity Deviation Cyl. 3, 0.07 mg/str
4, Injection Quantity Deviation Cyl. 4, 0.00 mg/str
Group 015:
Fuel Consumption, ,
1, Engine Speed (G28), 797 /min
2, Engine Torque, 40.0 Nm
3, Fuel Consumption, 0.44 l/h
4, Torque Request (Driver), 0.0 Nm
Group 016:
Auxiliary Heating, ,
1, Generator Load, 38.4 %
2, Auxiliary Heating,Shut-Off Conditions, 11000001
3, Heating Element Activation, 00
4, Supply Voltage (Terminal 30), 14.229 V
Group 017: Readiness Code (EOBD), ,
1, CARB Mode 01 DATA A, 00000000
2, CARB Mode 01 DATA B, 00000110
3, CARB Mode 01 DATA C, 11100000
4, CARB Mode 01 DATA D, 00000000
Group 018:
Injector Status, ,
1, Injector Status Cylinder 1, 0.0
2, Injector Status Cylinder 2, 0.0
3, Injector Status Cylinder 3, 0.0
4, Injector Status Cylinder 4, 0.0
Group 019, ,
1, , 133.25 V
2, , 131.75 V
3, , 130.75 V
4, , 133.50 V
Group 020: Injection Quantity Limitation (from ABS), ,
1, Engine Speed (G28), 798 /min
2, Engine Torque, 39.4 Nm
3, ASR Limitation, 1024.0 Nm
4, MSR Limitation, 0.0 Nm
Group 021: CAN-Databus Status (Powertrain), ,
1, Engine Electronics, 00000000
2, Transmission Electronics, 01000000
3, Brake Electronics, 00000000
4, Brake Electronics (ESP), 00000100
Group 022: Shut-Off Status, ,
1, Shut-Off Status Cruise Control, 1
2, Switch Monitoring Cruise Control, 0.0
3, Shut-Off Status Charge Pressure, 0.0
4, Shut-Off Status Climate Control, 0.0
Group 023:
Injector Switch Time Deviation, ,
1, Switch Time Deviat. Cylinder 1, 0.22 ms
2, Switch Time Deviat. Cylinder 2, 0.22 ms
3, Switch Time Deviat. Cylinder 3, 0.21 ms
4, Switch Time Deviat. Cylinder 4, 0.22 ms
Group 024, ,
1, , 789
2, , 789
3, , 776
4, , 793
Group 025, ,
2, Status Terminal 50, OFF
3, Engine Condition, Idle
4, Start Cancel Conditions, 237.0
Group 027, ,
1, ,
2, ,
3, , 0.0 km/h
4, , 300.0 km/h
Group 028: Accelerator Pedal Position Sensor, ,
1, Accel. Pedal Pos. Sensor 1 (G79), 0.756 V
2, Accel. Pedal Pos. Sensor 2 (G185), 0.375 V
Group 029: Temperature and Oil Level Sensor (TOG), ,
1, Oil Temperature, 86.0°C
2, Oil Level, 28.0 mm
3, Wear Index, 0 km
4, Soot Index, 0 km
Group 30, ,
1, Resistance, 75 ohms
2, , -0.01
3, Lambda,, 0.8 %
4, , 1.0
Group 31, ,
1, Count,, 0
2, Duty Cycle, 4.7 %
3, Voltage, 0.185 V
4, Voltage, 2.025 V
Group 32, ,
1, Count, 0
2, Temperature, 17.2°C
3, Pressure, 1021.2 mbar
4, Voltage, 2.025 V
Group 33, ,
1, RPM, 800 /min
2, Temperature, 147.7°C
4, Mass Flow, 7.57 g/s
Group 041, ,
1, Duty Cycle, 96.0 %
2, Duty Cycle, 51.1 %
3, Lambda, 52.1 %
4, Lambda, 7.8 %
Group 042, ,
1, Voltage, 0.781 V
2, Bits, 00000000
3, Lambda, 95.8 %
4, Lambda, 52.1 %
43, ,
1, Lambda, 85.1 %
2, Lambda, 85.0 %
3, Voltage, 3.648 V
4, Voltage, 3.648 V
Group 044, ,
1, , 807 /min
2, Mass Air / Rev, 292.6 mg/str
3, , 0.0
4, , 5.0 %
Group 045, ,
1, ,
2, Pressure, 0.0 mbar
3, Mass Flow, 7.58 g/s
4, Absolute Pres, 1010.9 mbar
Group 046, ,
2, Duty Cycle, 96.0 %
3, Lambda, 96.0 %
4, Lambda, 11.4 %
Group 047, ,
1, Voltage, 0.498 V
2, Voltage, 4.628 V
3, Lambda, 10.8 %
4, Lambda, 96.0 %
Group 051: Engine Speed Recognition, ,
1, Engine Speed, 798 /min
2, Camshaft Speed, 399 /min
4, Shut-Off Status Injection Sequence, 00000000
Group 053, ,
1, , 0.053 Nm
2, , 0.052 Nm
3, , 0.050 Nm
4, , 0.053 Nm
Group 054, ,
1, , 5.89
2, , 5.89
3, , 5.89
4, , 5.89
Group 062:
Engine Cooling (Temperatures), ,
1, Coolant Temperat. Engine Output, 88.0°C
2, Coolant Temperat. Cooler Output, 51.0°C
3, Ambient Temperature, 17.2°C
4, Intake Air Temperature, 34.0°C
Group 063:
Engine Cooling (Climate Control), ,
1, Refrigerant Pressure, 6.20 bar
2, Load Torque, 5.0 Nm
3, Cooling Request, 0.0 %
Group 064:
Engine Cooling, ,
1, Coolant Temperature (G62), 88.0°C
3, Coolant Fan 1 Duty Cycle, 9.8 %
4, ,
Group 67, ,
1, Temperature, 162.0°C
2, Temperature, 163.9°C
3, Absolute Pres, 8.2 mbar
4, Pressure, 0 mbar
Group 68, ,
1, Lambda, 10.2 %
2, , 8.88
3, Lambda, -2.6 %
4, ,
Group 71, ,
1, 803 /min, RPM
2, Inj. Quantity, 0.0 mg/str
3, Ign. Timing, 44.0 °ATDC
4, Idle Stabilization, 0.0°KW
Group 73, ,
1, Tank Cont, 2.9 l
2, Mileage, 46 km
3, ,
4, ,
Group 74, ,
1, RPM, 804 /min
2, Temperature, 162.0°C
3, , 1.0264
4, Inj. Quantity, 0.00 mg/str
Group 75, ,
3, Lambda, 10.2 %
4, Temperature, 154.7°C
Group 090: EOBD/OBD-2 Exhaust Gas Recirculation (EGR) I, ,
2, Injection Quantity, 4.8 mg/str
3, Exhaust Gas Recirculat. (spec.), 280.0 mg/str
4, Status Control Deviation, 00000000
Group 091, ,
1, Lambda, 100.0 %
2, Lambda, -100.0 %
3, Mass Air / Rev, 280.0 mg/str
4, Lambda, 0.3 %
Group 093, ,
1, , 00000000
2, , 0.98
3, Mass Flow, 7.04 g/s
4, Mass Flow, 11.24 g/s
Group 115, ,
1, Lateral Accel., 3.00 m/s^2
2, Torque, -32.0 Nm
3, Torque, 0.0 Nm
4, Torque, 0.0 Nm
Group 117, ,
1, , 0.0
2, , 99.0
3, Lateral Accel., 3.00 m/s^2
4, Lateral Accel., 0.00 m/s^2
Group 131, ,
1, , 0.0
2, Inj. Quantity, 4.9 mg/str
3, ,
4, Temperature, 88.0°C
Group 133, ,
1, , 802 /min
2, Mass Air / Rev, 283.7 mg/str
3, Absolute Pres., 1010.8 mbar
4, , 0.0
Group 150, ,
1, , 797 /min
2, Torque, 0.0 Nm
3, , 255.0
Group 151, ,
1, , 799 /min
2, Torque, 37.0 Nm
3, Torque, 170.0 Nm
4, Torque, 141.3 Nm
Group 152, ,
1, , 802 /min
2, Torque, -2.8 Nm
3, Torque, 36.4 Nm
4, Load, 34.9 %
Group 154, ,
1, , 795 /min
2, Mass Air / Rev., 280.0 mg/str
3, Mass Air / Rev., 278.1 mg/str
4, Duty Cycle, 52.5 %
Group 155, ,
1, , 797 /min
2, , 800 /min
3, , 00001001
4, Duty Cycle, 0.0 %
Group 156, ,
1, , 802 /min
2, Speed, 300.0 km/h
3, Speed, 0.0 km/h
4, Torque, 36.6 Nm
Group 157, ,
1, , 801 /min
2, Time, 0.00 s
3, Temperature, 88.0°C
4, , 11111111
Group 158, ,
1, , 792 /min
2, Torque, -6.2 Nm
3, Torque, 38.8 Nm
4, , 0.0
Group 161, ,
1, , 801 /min
2, , 7
3, Tank Cont, 2.9 l
4, Mileage, 46 km
Group 165, ,
1, , 805 /min
2, Lambda, 54.0 %
3, Mass Air / Rev., 269.8 mg/str
4, Duty Cycle, 51.0 %
Group 166, ,
1, , 801 /min
2, ,
3, Absolute Pres, 1010.3 mbar
4, Lambda, 3.648 V
Group 167, ,
1, , 796 /min
2, ,
3, Temperature, 71.0°C
Group 168, ,
1, ,
2, Voltage, 0.750 V
3, Voltage, 0.375 V
Group 194, ,
1, RPM, 796 /min
2, Inj. Quantity, 5.1 mg/str
3, Speed, 0.0 km/h
4, Temperature, 87.0°C
Group 213, ,
1, RPM, 799 /min
2, Duty Cycle, 0.0 %
3, Speed, 0.0 km/h
4, (no units),, 0.0
Group 235, ,
1, RPM, 798 /min
2, Lambda, 49.9 %
3, Mass Air / Rev, 284.4 mg/str
4, Duty Cycle, 52.3 %
Group 236, ,
1, RPM, 797 /min
2, ,
3, Pressure, 8.40 bar
4, no units, 0.0
Group 237, ,
1, RPM, 799 /min
2, ,
3, Absolute Pres, 1011.2 mbar
4, Voltage, 3.648 V
Group 238, ,
1, RPM, 799 /min
2, ,
3, Load, 34.9 %
4, Voltage, 14.118 V
Group 239, ,
1, RPM, 802 /min
2, ,
3, Mass Air / Rev, 283.1 mg/str
Group 240, ,
1, RPM, 803 /min
2, ,
3, Mass Air / Rev, 281.5 mg/str
4, Duty Cycle, 96.0 %
Group 241, ,
1, RPM, 800 /min
2, ,
3, Temperature, 87.0°C
Group 242, ,
1, RPM,, 802 /min
2, ,
Group 243, ,
1, RPM, 801 /min
2, ,
3, Bin. Bits, 11111111
Group 244, ,
1, RPM, 801 /min
2, ,
4, Duty Cycle, 9.8 %
Group 245, ,
1, RPM, 800 /min
2, ,
3, Mass Air / Rev, 284.8 mg/str
Group 246, ,
1, RPM, 799 /min
2, ,
4, Voltage, 14.229 V
Group 247, ,
1, RPM, 792 /min
2, ,
3, Bin. Bits, 11000001
4, Voltage,, 14.118 V
Group 248, ,
1, RPM, 799 /min
2, ,
Group 252, ,
1, , Airbag 1
2, ,
3, ,
4, , HVAC 1
Courtesy of Vince47
Well, having had my first play with VCDS to get the above for Martin I am amazed at the amount of info it displays. I would love to know more detail about what each value means but having said that the knowledge wouldn't be of much practical use as an average owner.
I notice that Group 29 above has no soot and wear values for my oil, perhaps thats a feature of me being on longlife servicing? (or it has no soot & wear!)
Pleased to see group 51 shows my camshaft is rotating at half engine speed; bit sorry for the BKC engine owner as his camshaft is a little slow:confused:;)
This sort of data is ripe for an analysis program which I guess is what VW dealers have?? Interesting stuff.
"I notice that Group 29 above has no soot and wear values for my oil, perhaps thats a feature of me being on longlife servicing? (or it has no soot & wear!)"
This is the sort of thing I am trying to find out about. My BKC on longlife has soot & wear figures but the other two logs don't have a value. That's why I need as many logs as possible.
