Just done an oil and filter change etc on my 1.9tdi B6 Avant.
How do I reset the Srvice Interval indicator
Tried a method from Haynes Manual
but it didn’t work.
Printable View
but it didn’t work.
Don't you pull out and hold the trip reset button or one button near the cluster.
Audi A4 (2001-2007)
For Fixed Interval servicing, you can use the following procedure:
Below and to the right of the speedometer are three buttons – the right-hand button of these three is usually labelled “0,0”, and the centre button labelled with a spanner/wrench symbol.
Start with the key in, but the ignition turned OFF
Press and hold the Spanner button, while turning the ignition on (position 2)
Release the Spanner button
“SERVICE” should now appear on the display
Press and hold the 0,0 button until the display shows “SERVICE IN xxxx Miles / Kilometres”
Release the 0,0 button, then turn off the ignition
Many thanks I’ll try it this morning
That is different to Haynes explanation
That didn’t work either
My car is automatic, as soon as I trlesde spanner button it shows message” press foot brake before selecting gear”
Any other suggestions gratefully received
I also have an automatic and Arman123 has the correct procedure as I have used it several times. Are you sure you turned the key to the 2nd position ( engine not started only ignition on) whilst pressing the wrench button.
I’m happy to try again in morning
Aha
Didn’t release spanner quick enough and then 0,0
Now says
SERVICE
IN
- - - MI
- - - DAYS
is this correct? Iwasexpecting to see
- - - 10000 MI
If I remember correctly once it has reset it takes a short drive to get it to appear with the info. Give it a day of normal use and see if it comes good.
Thanks again
I’ll give it a go tomorrow on my way to work
