Re: A6 Allroad Steering locked and non starting
Quote:
Originally Posted by
smaugc6
Scan the car you should get a steering column lock actuator fault, if you reset it the car will start again.
You'll need press brake hazard and high beam and then you can get access to the vehicle diagnostics without ignition.
I have done that and cleared codes, basic options was not highlighted so did not have ability to reset, do I have to enter a security code to get access and if so what is it? Because none of the ignition lights come on I wonder if there is a different issue. Been through all fuses, all OK.
Yes (DUH!) Battery is good, nearly new, nonetheless I charged it all night, problem persists.
Was there a code in the start authorisation module for steering column lock actuator
06 Audi A6 ignition problem solved - YouTube
Have a look at this video this should explain it, because yours is a manual I think the key doesn't get stuck.
smaugc6
You are rather ahead of me here, the computer is just borrowed, I don't really know what I am doing. I looked in 15 Steering, found and deleted codes (the date and time on those codes was some hours after the initial problem arose) but the options button where I had hoped to find the reset option was not available. Where is the start authorisation module?
I think it's module 5 the acc/start auth module that you need to scan and there should be a fault for a steering column lock actuator.
smaugc6
Yes there are faults relating to that in Add 05 acc/start, add 08 hvac, add 09 cent elec and add 19 can gateway. Laptop battery flat have to wsit a while. So there should hopefully be a reset option in the 05 acc/start area.
Perfect just reset the codes and it should start again, keep posted if it does.
Sorted, Massive thanks smaugc6, would not have done it without you, WONDERFUL!!!!!!
I love it when a plan comes together! :D
mhobson
Does anyone know if this works in vcds-lite? Or does it need full blown vcds?
