Re: A4 B7 Multitronic - please help figure out this strange gearbox phenomenon
Noise seems to come from shaft end that goes in to the gearbox removed brake discs and noise is stil there will remove shaft then see if it still makes noise will keep you guys updated noise has gt worse
Also if i jack up car and put in to D driver side wheel spins then slows down like its getting stuck, passenger side spins freely brakes are not binding
