This should be the chap:
GENUINE VW AUDI SEAT SKODA DIESEL FUEL TEMPERATURE SENDER 038906081B | eBay
You can always send the seller a question with your VIN to confirm, but pretty sure as your photo shows 81B as the last letters :)
Printable View
Great, thanks.
I managed to unclip the sender unit with its O ring, without disconnecting the fuel pipes. Measuring the sender unit, it reads 6K Ohms at ambient (today) and about 1.5 in hot water, so it seems to functioning. With the ignition on, the connector has 5 volts on the pins. So, unlikely to be a wiring fault but maybe the sender is out of range. I will get a new one, but does Anyone know what the sender resistance range should be ?
