RNS510 + aftermarket amplifier
I have a 2012 VW CC (it is the facelifted model but still has a Type 3C chassis) with a "Model D" RNS510 head unit that bears the part number 1T0 035 680 D. It is currently running firmware 5274 without any issues.
Recently, I have upgraded the 8 factory drivers (4 mid-low and 4 high) to a set of aftermarket speakers, which are also working great. Of course, it doesn't take a genius to realize the RNS510 is incapable of driving them to a satisfactory-sounding level and going down this path the next logical thing to do is to add an amplifier and a sub-woofer, since the feet are already wet. The wife will probably disagree but I'll leave that for a separate post.
I went ahead to acquire a 4 channel class D amplifier as well as an 8" sub. Before installation, I saw multiple forum threads (including posts from this forum) that points to some VCDS coding which does the 4 things below if one is retrofitting a factory amplifier:
- Lower the audio output on the RNS510 from speaker-out to pre-out;
- Set the sound system to drive active speakers instead of passive speakers;
- Disable speaker monitoring function;
- Set equalization to Linear (which is already the current factory setting of my car).
Assuming it also works for non-factory amplifier, I fired up VCDS and proceed to open Controller 37 and make the necessary changes. Code accepted. But to my surprise when I open Long Coding again, the old coding is still there. So I restarted the RNS510 by pressing Alt-Ctrl-Del (I mean < > *). Still the same. I tried coding at Controller 56, same results. Locked the doors and left the car overnight, same. The 10-byte coding is not updated no matter how I try. Frustrating as it is, there was no error message either.
Here is a scan of the controller, which does not change before or after coding:
Code:
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 D
Component: RNS-MID H61 5274
Revision: AB001001 Serial number: VWZ6Z7M4006078
Coding: 04000402040000A0000F
Shop #: WSC 05314 123 12345
VCID: 377CA2A0862E84F912-8062
Subsystem 1 - Part No: 7L6 919 859 J
Component: SIMA V6 8254
No fault code found.
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
So the option left would be to change to an aftermarket HU or to proceed as is. Aftermarket HU also comes with the penalty of losing integration features so I would really want to do that as a last resort. I now have the following concerns hoping you can help:
- Is the coding issue I describe above common and is there any known workaround?
- If the speaker monitoring cannot be disabled, once I connect the RNS510 to the aftermarket amp, would the audio output be disabled or it will just log an error code?
- Which would result in more severe audio quality deterioration, inserting speaker level to line level adapters or feeding speaker-out signals to the amp as-is?
Your help will be greatly appreciated! Thank you :)
