Does any body know how to code a reversing camera into rns-e? People keep going on about long coding but I have no tab for long coding. Any help would be great.
Printable View
I think it’s in adaptations or basic setting in OBDEleven.
Long coding is when using VCDS, you need someone with OBD11 experience, I only have VCDS, VCP and ODIS experience.
Yes, it is within the module. I assume it is nav you need to code? Could also be central electrics.
Click on the module and you will then be given a list of options. One of these should be adaptations. So long as you don’t write any coding by long pressing the tick you can poke around and see what settings are in there easily.
Done the coding but I have the following problem
Right I’ve connected white wire to pin 2. The camera comes up on the screen when in reverse but the radio screen goes black when in drive.
I’ve taken the white wire out of pin 2 and the radio screen stays on all the time but no reverse camera when selecting reverse.
What am I doing wrong? My chamber C is the reverse of the diagram on the instructions.
