Re: P0238 manifold boost pressure high Leon Fr mk2 facelift cr engine
thanks for the picture
I'll get that checked out asap and get back to you
Thank you very much
Do you know what the part is to the right of the egr, as the mechanic replaced that as he said its something to do with the vacuum, it has 2 vacuum pipes connected along with an electrical plug
Quote:
Originally Posted by
Shakeeb_5
Is the diverter valve located at the front, to the right of the egr valve on the cr 2.0 tdi engine?, as i've had that replaced as well
It's the circled part.
Hello
I've had the diverter valve checked, it is holding vacuum according to the mechanic, and he replaced the n75 valve with a new one, still same issues so he replqced the diverter valve with a used one (he'a got a breakers yard) and still the same issue
