I just ordered up parts to do front and read discs and pads.
Do i need to change the caliper carrier bolts?
Can anyone give me the torques settings for:
Caliper bolts.
Caliper carrier bolts.
(Front and rear..)
Thanks guys!
Printable View
Caliper bolts.
(Front and rear..)
Thanks guys!
It depends on the system fitted as to whether you can re-use the bolts and the torque. I would need you VIN to look them up.
Ok thanks.
My VIN is WVGZZZ5NZ9W022214
Engine code CBA
prod this thread in the morning and I will look it up at work.
Your very kind! Thank you.
Bump :-)
Hi Crasher,
If you get a chance today, really appreciate it.
James
Looks like it could be:
Front:
Caliper bolts 30nm
Caliper Carrier 190nm
Rear:
Caliper bolts 35nm
Caliper carrier 90nm + 90deg
Wheel Nuts 120 nm
If anyone can confirm, would appreciate.
