Passat 2.0 tdi sport 2005 by
Hi any advice will be much appreciated
Having issues with the glowplugs all 4 the garage I used fitted 4.4 glowplugs which were from parker's car parts
On diagnosis showing all 4 are intermittent my engine management light is on when I start the car I get a message saying emissions workshop
Have been told might be the wiring loom or the glowplug relay has anyone had this issue with a successful repair
Re: Passat 2.0 tdi sport 2005 by
Hi I'm sure this isn't right place to post but welcome... Here is a link to check out it may help you? “Engine and emissions workshop” keep popping up on my dashboard - Daily Monitor
Welcome to the forum. I have moved the thread to the correct area.
There are 2 glow plug voltage circuits for PD engines one using 7v covering most 2.0 engines up to May 2007 (like my early 2007 BMR) and 4.4v from June 2007.
Yours being a 2005 should have 7v plugs not 4.4v if it has a BKP, BMP or BMR engine which is likely. BMP are size M10 and the others M8.
You have the wrong plugs it seems?
Quote:
Originally Posted by
Nabz1310
Appreciate your intentions but bit of a 'Chocolate Teapot' moment in this instance.
