Re: Help with VCDS audi fault code terminal 30 U140A 00 [032]
Hello There, been living with this for more than 2 years ... eml permantly lit because of a needle dance pre-ignition terminal 30 fault ... and it has now hidden genuine faults from flagging up the eml cos its always there!!!
So just out of interest did the relay swap solve the problem .. or did you have to chase it with a multimeter?? How did you solve the problem?
cheers ..
Quote:
Originally Posted by
mavrick26
Hi Bruce
Many thanks for your reply, i will try a relay and let you know how things go with it
Hi, please would you let me know if you/how you solved this terminal 30 fault?
many thanks
Andy
