Re: Opinions wanted.. Oil leak noticed after 1 month of purchace from dealer.
what car have you got ??? if it is a direct injection tdi the piston crowns are recessed(thats the combustion chamber -the old ones had flat piston crowns combustion chamber in the head- so there was a chance of oil contaminating engine oil)---take note---the CR-common rail systems do not like pure veg/sunflower oil it needs to be thined down !! but yes I am not joking !!
Quote:
Originally Posted by
mphojan-MJ
Honestly does veggie oil work on a car or your just entertaining us here? I wanna try it but I'm I don't want to disassemble my engine changing the piston rings! Does it smell like chef Gordon's kitchen?[emoji23][emoji23]
If its fresh veg/sunflower-not realy that much smell-if its old used them yeh a smell of burger-chips-or what ever its been cooking-and when I use old stuff it gets filtered throgh an old pair of Levi's----no joke !! leaves mor coin for:beerchug::beerchug::biglaugh:
Ooh so it is used in your fuel system not as a lubricant?
And for Diesel engine not patrol
I don't own a car yet but I thinkin of get a corsa utility 1.8 sport or 1.7tdi sport or may a mk4 gt 1.9tdi or GTI 1.8
mphojan-MJ
mk4 1.9 tdi it will be a VE engine---they love the veg/sunflower oil, ran one for yrs no probs what so ever apart from one fuel filter after first two tanks of veg !!!
Vagnuts
Do you put in just the veggie oil or you mix it with the diesel?
mphojan-MJ
99.9% of the time I run 100% veg/sunflower oil, when it get cold the veg thickens so need a wee bit thining out, but if the engine is warm to start with no thining needed, just put pump fuel in before ya stop it, if its going to be cold next time you go for start !!! usualy in realy cold weather I would put a two to one mix--two gallon veg to one diesel !!!
but the VE engines I used 100% all time, never had a prob--even in the coldest of weather !!!
By wee what do you mean
