Thanks! How do I remove the cover? Is it the soft rubber/plastic bulbous part that sits directly above the dash?
Printable View
Hi Chris - would you be able to send me the diagram too please (it's for a 2015 Q7 if that makes much of a difference ....). Thanks!
Hi Chris please send me the diagram too. I have an Audi A7 - it's has tiny particles of glass sitting in side the HUD from a previous windscreen replacement. Thanks
Hi Usmannh
Are you sure the bits of glass are inside the HUD as it is a sealed unit and not even dust can get in until you undo 4 screws. If you need to remove the HUD to get at anything the windscreen needs to be removed. There is a common problem with these Hud's that looks like glass inside but is infact the mirror surface inside flaking off.
Hi Chris,
Sorry to resurrect this one - but I've been having the same issue for a long while, and finally cant take it any more!
Final straw was giving a lift to a friend, who could only mention the 'squeak' (arghhh).
Please can I have a link to the diagram/info for removal. The garage tried foam inserts, but it looks crap, and hasnt fixed it. Will do it properly myself.
Appreciate it,
Alex
There is a proper, Audi recognised fix for this now.
Sent from my iPhone using Tapatalk Pro
I did mate. They did it during a service and it was out of warranty.
I'm going to have to take mine back too. It's in warranty so should be no issues. Thing is, it doesn't happen all the time, but once it starts to vibrate (normally because of a rough surface) it won't stop until I leave the car a while.
Mitchy any more detail about the fix, for ammo against the dealer. Something to quote at them, a code or recall maybe.
I've also got an odd rattle from the passenger door, but I can't for the life of me figure out where it's coming from. That's worse than the hud rattle as it's all the time.
Nothing further I’m afraid mate. I’ll check the receipt when I get home at the weekend. I told them about the issue and they said there was a fix issued by Audi. Got it sorted at Cheltenham Audi if they need to call them. They thought it was a screen out job but did it all in place
