3 Attachment(s)
**UPDATED** Adding images to posts using "insert image" option
For some reason vBulletin have changed the way images are attached, and sized when putting in posts...
So, a quick guide....
1. Start you post
2. Click the "Insert Image" icon in the tool bar.
Attachment 16939
3. Select "from computer" from the "insert image" pop up box:
Attachment 16940
4. Select your image and upload it...
This is pretty much the same as before, but this is were the changes are.
5. Once your image appears in your post, but BEFORE you click "Submit New Thread", DOUBLE CLICK THE IMAGE!!!!
You will be presented with the options to select the size location you want to appear
Attachment 16941
Then click "Submit New Thread"
I have no idea why they have made these changes, seems a backwards step to me, but I have no say in the matter .. :)
Hope this helps.
Stuart
Re: **UPDATED** Adding images to posts
I take it my old guide is now redundant because of the change, or does it only apply to the image upload?
This applies if you want to put an image n a post using the "insert image" icon, I think your post applies to the "attachment" option ;)
Yes, I see. Yep mine is the attachment .. Doh!
Just tried it, the image re-size option is the same... I will update your post ;)
