Re: Retrofitted RNS-510, Changed GW, now a lot of errors
My mistake. Your original coding was correct. Do the original code again but make up some numbers for workshop code, Importer, Equipment. Something like 1234.....123....12345.
This is what ross-tech recommend.
Then try to open module 37 navigation. If it opens have a look at the coding.
Quote:
Originally Posted by
martin1810
My mistake. Your original coding was correct. Do the original code again but make up some numbers for workshop code, Importer, Equipment. Soething like 1234.....123....12345.
I tried changing the values for workshop code, Importer, Equipment and will not let me change them. How could I?
If it won't change then you can't change it. I am out of ideas. You could try recoding the gateway to F9807F16500302001002. This should not work but it is worth a try.
martin1810
that does not work, the end I will return the gateway to the ebay seller, thank you very much for everything
The eBay seller told me this:
"You need to cut pin 2 inside the box. Like on the 530 L. Otherwise no.
This fault is from the RNS-510, I think it is bad coded. He needs to remove unit 37 and 56 from the Can gateway, remove key from car, and reinsert key in car. login into can gateway again remove errors, and add unit 37 & 56 again and test for errors.."
and I have seen this in another forum:
Hey.
The part number is : 3C0907530 and should end with either H, L or Q but remember if you intall the L or Q version you have to take the gateway apart end cut the 2. pin from the right otherwise the gateway will be toasted and you have to buy a new one.
http://i278.photobucket.com/albums/k...r1/cangate.jpg
The can gateway is placed just left of the gas pedal and a little up there is a 20 pin blue plug in it.
I have never heard of cutting pins before. I would not do that as the gateway may end up as scrap.
thats a bit drastic..... maybe e bay sell loads with those instruction .... 100% positive to not work again.............
drizzt dourdem
Did you try at the start page. under settings and user interface. Change codes from 00000 etc to 12345 etc.
That should work. Then recode with you original 10 byte code.
martin1810
I test all 530Q gateway that I have on a Passat 3C 2008,
this Passat come with 530E,now using 530L,all work well.
and I test all 530Q on this 2008 Passat today.
my VCDS 10.6.1 set code as 12345, importer as 123, equipment number as 12345
all 530Q have this error code.
can't communication with RNS510
at this moment, I think 530L is the best choice,
but it was dropped and replaced by 530Q in ETKA.
:confused:
Thanks for you reply mango99. I think you are correct. I think the 503 "Q" has a change that we don't know about yet. At present I would say we cannot use 503 "Q" as an upgrade gateway.
