Coolant temp sensor location Audi A3 1.8 Turbo X reg 2000/2001 model year
Audi A3 1.8 turbo 2000year Coolant temp sensor location??
Coolant temp gauge always read zero, but the car heater blowwarm/hot air and the car never overheats.
I have been to local motor parts factor and they said thereare 2 coolant temp sensors
1 is a short fat sensor with a square 4 pin connector
1 is a long sensor with a rounded 4 pin connector
Where in the engine/engine bay are they located?
Thanks for your help
Re: Coolant temp sensor location Audi A3 1.8 Turbo X reg 2000/2001 model year
Hi All,
I have had a good look today and found 1 of the sensors.
At the end of the cylinder (above the gearbox) I found the long sensor with a rounded 4 pin connector changed it
Checked coolant level.
Ran the car and the temp gauge on the instrument cluster now works OK :o
Had a good look round the engine but could not see another temp sensor ?
Is the other one on the bottom radiator hose or lower radiator flange. ?
Found them both fitted temp gauge on dash now works ok
But car will still not start when hot? - please see new post for this Audi A3 1.8T AGU Engine Will not start when hot!!
