Thnak you very much, thIs is now clear for me.
Kind Regards
Printable View
Kind Regards
Hi Jim,
Have you checked the fog and reversing lights are the right way round ?
I was looking at the coding of the central convenience module on my car the other day and tried to work out how the code was derived. When I added up all my options, it came to a number higher than the coding. If I took out the code for "Right hand steering" I got the right code.
Just wandering if they added the code for Right hand steering to yours. I think that may control which side the fog light is. Could be wrong though, I'm certainly no VAG COM expert.
Dave
Hey Nobby, sorry I haven't had time to check but I'm sure they're fine - havin said that you know I'll check the next time I'm out n about in her....lol
Too busy tryin to get the rear number plate leds to stop throwin codes....they look the absolute mutts nutts but only stay on for around 30 secs and then the bulb out light comes on......looks like I need to get a resistor put in......any ideas who could help with this for me?
Already done the dome interior lights and just waiting for the map reading lights to arrive to do them too.
Jim
Only had my 2007 A6 a few weeks and after washing it at the weekend have noticed fogging of the rear light cluster and also side indicator lenses.
I'm taking it in on friday to have it looked at and hopefully replaced. I've already got the highline tail lights so I'm guessing they will just swap them.
Has there been a fix for this problem or is it that some of the seals were just dodgy?
Hey there Spinney.....If you have the later versions, chances are they'll just swap them out for you. They have at least 2 different suppliers I believe.
I found that the later ones I received were from a different supplier and once fitted had no problems since.
Just remember - take no nonsense and stand your ground, especially as you're still under warranty.
This is a known issue
Cheers Jim,
I might print off this thread and take it along just in case!
Jeeesh - the drivers side rear light has serious condensation AGAIN.....well, more like water droplets accumulating and it looks nasty:mad:
Called the dealership to complain yesterday - to be absolutely fair to them. They've arranged not only to replace the light and re-seal it, but also to send out a mobile tech to carrry out the work to my home address.
This'll be the 6th light replaced to date though - not good!
Jim
Darn! Was this with your new Highline LED rear lights? We were all hoping your problem was fixed by having these fitted.
Sorry to hear you're still struggling with the problem. Keep smiling!
MF.
Hey MFGF, unbelievable I know. What gets to me more is the fact that there are hundreds of Audi drivers out there all suffering the same problem and not shouting about it:mad:
Sheer weight of numbers seems to be the only way they are gonna rectify the problem.
I did hear, that they were designed to "breathe" to allow for this condition, which I find strange. I woulda thought they would have been sealed which is what the dealership were told to do by Audi on my last set. The passenger side is still ok, just the drivers side gone, so maybe they just didn't manage to seal that side as well?
