Re: Golf 1.6 unstable RPM, ticking noise, car sometimes dies when coming to a stop.
Hi Crasher,
Thanks for your reply. What would you advise? Are there any that may be compatible?
Not as far as I know, there are no alternative numbers.
Thanks Crasher. It seems I have a problem now.
ECU failure is not a common problem
Could anyone help me source an Engine Control Unit?
VW Golf MK4 1.6. VIN: WVWZZZ1JZ2W241292. Engine serial number is AVU085667. Would anyone be able to source for me the ECU? The Part # 06A 906 033 AF.
If I get a used part, is it possible for it to be reprogrammed for my car or must it be a brand new OEM part?
Thank you.
A used ECU or a new ECU will both have to be programmed and matched to your cars immobilser system
Thanks for the response. I am looking for that part. In case you have anyone who can supply me please share their contacts.
