Does anyone have experience of the ESP warning light on the dash?
I have a 2004 Touran and the ESP lwarnng light shows permanently on the instrument panel. Recent diagnosis by VW dealer advises new ABS sender required; estimated cost £1500, yes £1500, including VAT and fitting (3.7 hrs), can anyone offer advice and help?
Re: Does anyone have experience of the ESP warning light on the dash?
Well, it is true that when there is a problem in the ABS system then the ESP light is illuminated. They could be right, but if you could get a VAG-COM fault code read done to tell us what the problem is then that would be very helpful.
Paul
It won’t be a sender but as Paul says, get the fault code number.
I back down to someone with superior knowledge... yes, just get a fault code read done. :p
Paul
My S3 had the ESP on all the time....well.....it was on all the time intermittently...so I took it to my boys (VAGTech) and it was a front pressure sensor...think they charged me less that £100...I was having all the brakes replaced at the same time, so the price was all a part of the bigger job.
But whatever it is, so pratting around with a dealer and get yourself a specialist!
I had this light come on, on my Golf luckly it stiil had 3 weeks VW warrenty running they sorted it out they had it 2 days and it was the ABS module.
Hope that helps you a bit.
Steve
Quote:
Originally Posted by
Vwsteve76
Steve
Hi guys,
Thanks for the interest you have shown in my problem. The only information I can get so far from the VW dealership is that the diagnosis came up as 0201 Sender ABS Control Unit
Hi guys,
Thanks for the interest you have shown in my problem. The only information I can get so far from the VW dealership is that the diagnosis came up as 0201 Sender ABS Control Unit. It seems unlikely that they will divulge any further info.
Can anyone let me know how to contact VW specilaists in my area? :1zhelp:I don't seem to be able to find a decent website that does this.
Where are you in the UK.
Also try looking in the vagcom section for someonr in your area.
Thanks for the interest in my problem; I live in Suffolk near Bury St Edmunds.
