  • stuart
    Page 201593 of 164 FirstFirst ... LastLast
  • Latest Poll
    swalker
    Re: injector deviation
    Cheers Crasher, I always run BP Ultimate, cant remember the last time i seen Shell over here,I will have to google that one.
    The more i think about
    swalker Today, 01:10 PM Go to last post
    Re: A4 B7 2.0L Tdi Cylinder Head
    Yes, it is called HIP treatment for Hot Isostatic Pressing. The tool is called T10262 and thinking about it, you can probaly just tap the carrier off
    Crasher Today, 12:55 PM Go to last post
    Re: DSG Fault Maybe
    006079 (P17BF) - Hydraulic Pump - 000 - Play Protection
    006300 (P189C) - Function Restriction due to Insufficient Pressure Build-Up
    Crasher Today, 12:46 PM Go to last post
    Re: Any idea what this is for?
    I did do part of a post and then forgot top send it, it said
    The first group of numbers denotes the type number of the car the plug was
    Crasher Today, 12:39 PM Go to last post
    Anything even approaching +/-1 is a problem. Stick a can of powerful cleaner in, Nirox I think, easy to get on a near empty tank and half fill it with
    Crasher Today, 12:37 PM Go to last post
    Re: Audi A3 8P Drivers window not winding down and central locking issues.
    Are the codes still the same?
    Crasher Today, 12:34 PM Go to last post
    franksand999
    Invisible coolant leak - RWD - EGR Cooler removal - best method
    I have a Crafter 2019 RWD 140ps, with a coolant leak issue, but no visible signs of a leak.
    I need to 1) pressure test the EGR cooler,
    franksand999 Today, 12:10 PM Go to last post
    bobfrankish
    I can now answer my own question, the heads can't be skimmed because it removes a coating which stops porosity. Just leaves the elephant-in-the-room special
    bobfrankish Today, 11:44 AM Go to last post
    daveplyjeep
    DSG Fault Maybe
    Hi all
    Just run this passed you all.
    My wife's car came up with a fault on the gearbox. The gear selector number
    daveplyjeep Today, 09:19 AM Go to last post
    johnsimcox
    Re: Diesel v hybrid
    A key consideration with the hybrid is that your journey pattern will be if. If it is lots of shortish journeys and you can plug the car in at home/work
    johnsimcox Today, 09:00 AM Go to last post
    Whippy53
    Re: Diesel v hybrid
    For the '50' ,
    "That's an average of 5.92l/100km (39.7mpg) from the self reporting of 37 owners."
    From here,
    https://www.spritmonitor.de/de/ueber...mp;powerunit=2
    Whippy53 Today, 07:48 AM Go to last post
    nevbadger99
    Diesel v hybrid
    Hi All
    My C7 is now at 115k miles and I'm considering moving to a C8. Obvious choice is to get another TDI as the 4 I've had so far have
    nevbadger99 Yesterday, 06:57 PM Go to last post
    D ave
    Hi Gareth
    You were 100% right it was the glovebox light plugged it in and hey presto a glovebox light!
    D ave Yesterday, 05:18 PM Go to last post
    bobfrankish
    Hi Crasher, thanks for the reply. This is what I feared re. the special tools. I wonder if you can hire that tool from anywhere? Purely out of interest,
    bobfrankish Yesterday, 04:50 PM Go to last post
    swalker
    injector deviation
    All this comes from a lumpy tick over at times and a rough first mile or 2 in the mornings if i am in a hurry.
    I am suspecting my #2 is a bit off,
    swalker Yesterday, 01:50 PM Go to last post
  • Recent Blog Posts
    Air suspension Fault
    It is £1975 from an Audi dealers parts department. A TPS MAY serve you and give you 10% discount BUT the TPS warranty system is a not fit for purpose joke so if you aren’t trade, buy it from Audi.
    Crasher 01-06-2024 09:55 AM
