  • stuart
    Page 201425 of 164 FirstFirst ... LastLast
  • Latest Poll
    audia4a3
    Re: Boost pressure sensor MAP good brand replacement?
    Hi crasher, just trying to squeeze another few months before this
    A3 goes to scrappy. 2004 2.0 TDI 204,000 miles had it 10 years it's tired. Any
    audia4a3 Yesterday, 10:23 PM Go to last post
    benmack
    Adblue Fault, Now Won't Start
    Help! Car won't start and we're in deepest Cornwall. It has been giving the adblue "no restart in X miles" for a few months, an intermittent
    benmack Yesterday, 08:12 PM Go to last post
    jc07030
    CRLB engine alternative
    Need to replace engine block for my CRLB engine on Audi A3.
    Have found whole engine with CRB code.
    Can someone
    jc07030 Yesterday, 07:39 PM Go to last post
    raffyrafs3
    Re: Golf R overheating - help required
    Hi, I got the exact same issue. I changed the coolant reservoir bottle, is that where the coolant level sensor is? or am i missing something?
    raffyrafs3 Yesterday, 03:26 PM Go to last post
    A6avantowner
    Re: A6 2002 2.5 TDI - won't start
    Yes, it looks like it, the only fault code I have now is:
    01268 - Quantity Adjuster (N146)
    37-00 - Faulty
    I've
    A6avantowner Yesterday, 01:57 PM Go to last post
    enoksen90
    Re: Touran 2.0TDI BMN cranks, no start
    new pump bought.
    enoksen90 Yesterday, 01:31 PM Go to last post
    New pump then.
    Crasher Yesterday, 01:26 PM Go to last post
    The codes and symptoms suggest the pump has failed, we would start by taking it off and sending it to a Bosch VEP specialist. We use Diesel Fuel Injection
    Crasher Yesterday, 01:25 PM Go to last post
    enoksen90
    I had the fuel filter out, the top of the filter was almost dry. syphoned the canister of diesel, were almost empty. Activated the fuel pump thru VCDS
    enoksen90 Yesterday, 12:47 PM Go to last post
    A6avantowner
    Thanks Crasher for looking at this.
    Are there some basic troubleshooting steps to determine that's the failed part?
    Like you, I suspected
    A6avantowner Yesterday, 11:10 AM Go to last post
    Careful it isn't a wiring fault code as a new MAP won't solve it, there is a VW repair kit for the wiring which has to be run directly into the ECU plug.
    Crasher Yesterday, 10:28 AM Go to last post
    That gives me the impression of lift pump failure.
    Crasher Yesterday, 10:00 AM Go to last post
    What can happen is the swirl pot pump in the tank fails (or the relay gets wet) and the injection pump pulls in air which causes the pump to run dry and
    Crasher Yesterday, 09:58 AM Go to last post
    dean warren
    Re: Buying a 2015 biTdi allroad!
    The BiTDi suffer from failure of the electronic small turbo actuator too, parts aren’t too bad as vw/Audi sell a repair kit, but there is a lot of labour.
    dean warren Yesterday, 09:17 AM Go to last post
    bobfrankish
    Re: 2.0L TDi overheating issue
    Hi Larhal, thanks for the reply. Yes, our "to do" list is firstly fit new EGR valve, we have EML light on and diagnostics say EGR fault. Car
    bobfrankish Yesterday, 08:22 AM Go to last post
  • Recent Blog Posts
