  • stuart
    Page 201425 of 164 FirstFirst ... LastLast
  • Latest Poll
    benmack
    Re: Adblue Fault, Now Won't Start
    Thanks Crasher, I think I might just get it deleted. We live in a rural area, emmissions are not so critical here
    benmack Today, 01:06 PM Go to last post
    benmack
    Thanks Gareth. I think it's a gamble I have to take, and just make sure I don't stall. The alternative is RAC it home from here, not much advantage
    benmack Today, 01:04 PM Go to last post
    Full Scan
    Re: MK7 Golf water ingress locations
    Just started to see the start of water leak from the bottom of my rear door speakers.
    Just need this Geo engineered weather to give
    Full Scan Today, 12:37 PM Go to last post
    Probably needs the revised active reductant tank, pump and controller 8K0 131 877 AB plus software update, £1842 plus 20 litres of AdBlue, ODIS SVM and
    Crasher Today, 12:36 PM Go to last post
    Full Scan
    Re: Hi from Milton Keynes
    Hi Crasher.
    Thanks for the welcome, I've added my VCDS location.
    Full Scan Today, 12:28 PM Go to last post
    Re: Polo Mk 5 1.2 2013 - P0335 & P0336
    The ECU and the harness were ruined. Replacing the ECU was complicated by it having an APR remap I had done a couple of years previously and I had to
    Crasher Today, 12:27 PM Go to last post
    Full Scan
    VCDS Scans, Read and clear DTC's Milton Keynes
    Can help out with full scans, read and clear codes.
    Unable to do coding due to limited Vin's on VCDS.
    Based
    Full Scan Today, 12:23 PM Go to last post
    I haven’t encountered that one yet, has it had a new matrix?
    Crasher Today, 12:20 PM Go to last post
    Hello and welcome, you could add yourself to the list if you wish VCDS - Users Locations
    Crasher Today, 12:18 PM Go to last post
    Full Scan
    Thanks for having me.
    No problems at the moment but nice to have somewhere to come if need be.
    I bought VCDS a
    Full Scan Today, 11:54 AM Go to last post
    Nick S
    Replacement drive shaft
    I need to replace the right front drive shaft on my 2003 B5.5 Passat Estate and VW tell me they not longer supply the part (8D0407272BC).
    Does anyone
    Nick S Today, 11:16 AM Go to last post
    gareth23
    The impression I get is that its no restart - if you dont stop the engine it will keep running, Audi would probably be liable if they programmed the Adblue
    gareth23 Yesterday, 09:28 PM Go to last post
    benmack
    Anyone know if I can do that again when the 35 miles expires?
    benmack Yesterday, 08:33 PM Go to last post
    rainon
    You must be thankful its a pretty rare thing
    Did you replace the affected harness? I imagine even if you dry off the connectors, the water
    rainon Yesterday, 06:08 PM Go to last post
    Hladd7
    VW Polo 18 Plate - Battery Drain from 5f Module Infotainment
    I was wondering whether someone could help me with some advice?
    I have a battery drain which, after VW diagnostics, has
    Hladd7 Yesterday, 05:03 PM Go to last post
  • Recent Blog Posts
